Mercury Racing Blue Anodized Pulleys
Who can strip my current blue pulleys and anodize them back in Mercury Racing Blue?
Originally Posted by Jim Diesel
(Post 4858883)
I don't know where you call home, but... Electro-Polish is a world class metal finishing facility in Dayton, OH. I don't know if they can do "Mercury" blue, but they DO have blue. You're probably going to have a difficult time sourcing an exact color match. I'd suggest going with hard anodize anyway, which is typically only available in clear or black. Thanks. Brad. (937)545-8991 |
(Post 4858892)
Jim,
(Post 4858902)
I'm in far West KY, but I will check them out. Thanks!
Just an FYI... I'd call them and talk about masking the ID bore for both stripping and re-anodizing. There is some considerable material loss in the stripping process, and you probably want to retain the fit to the shaft. Thanks. Brad. (937)545-8991 |
(Post 4858903)
Jim,
Just an FYI... I'd call them and talk about masking the ID bore for both stripping and re-anodizing. There is some considerable material loss in the stripping process, and you probably want to retain the fit to the shaft. Thanks. Brad. (937)545-8991 Will do, Thank you! :drink: |
Hey JD, Ive powder coated them with two stage silver under coat and a bright blue top turns out well.
https://cimg3.ibsrv.net/gimg/www.off...2bf2ec59ca.jpg |
(Post 4858913)
https://cimg3.ibsrv.net/gimg/www.off...2bf2ec59ca.jpg I wondered about powder coating, given my recent positive experience with it on some cleat bezels. I just wonder about the wear factor. Have you run these pulleys? If so, how did they wear? Thanks. Brad. (937)545-8991 |
Thanks F2!
Silly question.
Are your pullies aluminum or steel? If steel, I would guess powder is the way to go. I don't think you can anodize steel. |
Originally Posted by xlint89
(Post 4859015)
Silly question.
Are your pullies aluminum or steel? If steel, I would guess powder is the way to go. I don't think you can anodize steel. You are correct. Steel cannot be anodized. Didn’t even think to ask that question. Thanks. Brad. (937)545-8991 |
| All times are GMT -5. The time now is 10:36 PM. |
