-   -   496 HO valve springs (https://www.offshoreonly.com/forums/general-q/378362-496-ho-valve-springs.html)
boatnt 02-11-2023 12:14 PM
Getting a couple of 496 HOs ready to install, while on the stands I'm a thinking of replacing the valve springs, any recommendations on springs or just leave them alone? Thanks
Smitty275 02-11-2023 01:57 PM
PAC seem to be the best. They live where others have failed.
Griff 02-11-2023 02:01 PM
Why replace them?? They should last 2000 hrs with the small cam in the 496
boatnt 02-11-2023 03:19 PM
just looking for trouble I guess,lol
Ryan00TJ 02-11-2023 06:56 PM
Stock HO cam? I would leave em alone.
boatnt 02-11-2023 08:10 PM
yep all stock HO
Ryan00TJ 02-11-2023 11:29 PM
How many hours on the springs? If you have the capability, remove a couple and test pressure. Shim them up to .080-.060" before coilbind if wanting to increase spring pressure.
boatnt 02-12-2023 09:16 AM
02 year 496HOs with 258 hours
Knot 4 Me 02-12-2023 09:21 AM
I'd send them.
boatnt 02-12-2023 10:33 AM
Originally Posted by Knot 4 Me (Post 4859098)
I'd send them.
starting to think the same
Ryan00TJ 02-12-2023 06:48 PM
Leave em alone. I would be more concerned with 2002 injectors if they have never been touched.
Ryan00TJ 02-12-2023 06:50 PM
Delete
Brad Christy 02-13-2023 07:12 AM
Ditto
boatnt 02-13-2023 09:06 AM
Originally Posted by Ryan00TJ (Post 4859124)
Delete
87MirageIntruder 02-13-2023 09:06 AM
I'd leave them alone with such low hours. They do have a weak spring pressure but they work fine with a stock cam. Plus they have all that funny rotator stuff from the factory.
I agree with others on getting the injectors cleaned. And perhaps replace the IAC valves so you don't smoke a PCM555!
Brad Christy 02-13-2023 09:09 AM
Originally Posted by Brad Christy (Post 4859146)
Ditto
Clogged Injectors
