Valvetrain Geometry and gross lift
When measuring gross lift for valvetrain geometry, do you use the intake and exhaust nr?
When they are different like mine, 610 .632 lift 236 244 dur. @ .050 114 lobe sep. |
Originally Posted by JanTore
(Post 4859331)
Originally Posted by kornegle
(Post 4859409)
Not sure what exactly you are trying to do, but if you want to measure the cam you would measure at least one intake and one exhaust lobe and they should measure at the specified intake and exhaust lobe lift. If you are checking geometry for pushrods, I usually get or make an adjustable pushrod, install it and change the lengths for each intakea and exhaust lobe until the rocker wipes the narrowest and best centered pattern possible on the valve stem. Then I call the company of my choice and give them the measurements to order the pushrods. Most companies sell them in 0.050" increments.
Have somebody done it the Jim Miller way? "A. Know your NET valve lift; divide in two; that is your MID-LIFT "motion" (MLM). B. Measure the height of your valve tip above the retainer. C. Measure the diameter of the roller; divide in half (this precisely gets you from the bottom of the roller to the AXIS). D. ADD "B" and "C" together, to get the STACK HEIGHT. An illustration can be found at: Jim Miller, Installed Geometry G1E. Now, use a straight edge like the little machinist square shown in this video, and lay it across the valve spring retainer and alongside the trunnion. F. SUBTRACT or ADD (as needed) the STACK HEIGHT to or from your MID-LIFT MOTION, by raising or lowering the rocker arm on the stud.>EXAMPLE:* NET VALVE LIFT IS .700", so MID-LIFT MOTION is .350". That's cut in stone, now forget it for the moment (you've written it down). * Valve tip is .050" above the top of the retainer; and the .500" rocker arm roller diameter tells you its radius is .250", so the STACK HEIGHT is .300".SOLUTION:If the STACK HEIGHT is .300" and the MLM is .350", then you need to place the trunnion .050" BELOW the valve spring retainer. If your math has the inversion of this, then your trunnion centerline would be above the straight edge coming off the retainer. SUMMARY:DO EVERYTHING IN THE CLOSED VALVE POSITION, AFTER YOU KNOW NET LIFT. It's much easier to get an accurate DIAL CALIPER measurement on hard points, to find their true center-lines, than trying to use visuals that only give you approximate values. You can use the outer edges of the trunnion's diameter and divide in two for its center, which is far more accurate than eye-balling." Jim Miller- |
(Post 4859331)
When they are different like mine, 610 .632 lift 236 244 dur. @ .050 114 lobe sep. The terminology used is “net lift” and lobe lift |
I may get some flak for this....
Mid-lift method - pain in the arse to get right. Much more trouble than it's worth. Jeff Smith has a write-up that works and is recommended by Trend: https://blog.trendperform.com/how-to...train-geometry |
Originally Posted by TomZ
(Post 4859462)
Mid lift is to much work for no gain. Straub Technologies has a great video and it's easy as pie.
Originally Posted by Smitty275
(Post 4859484)
Mid lift is to much work for no gain. Straub Technologies has a great video and it's easy as pie. https://youtu.be/o5is9BsH5OU
Maybe i'm just overthinking this whole procedure, but i will now use this video and the link from TomZ, and ignore all the rest:) |
(Post 4859484)
You really have to do this with a solid lifter that is the exact height of the lifters you’ll use. If the lifter is hydraulic and not pumped up, you have to be very precise with the feel while taking the slack out via the adjustable pushrod - you do not want the lifter plunger to move.
I use a 12-inch digital caliper to measure the overall length. Once you have your measurement, add your preload (I added .025 to the length - 1/2 a turn). |
Some engines with certain cylinder heads (like dart) have mediocre to bad valve train geometry to 8 valves at best. This can be corrected with custom rocker arms half sets from like crower. I was building a 565 with profiler heads, if i remember right the intake geometry was terrible. Was what I call a "10 hr rebuild engine" , ie, was going in something that would maybe see 10 hrs run time before its next rebuild being abused in its application. Had a cam that would result in a about .800 lift. Customer would NOT buy shaft rockers and we couldn't get the custom crowers by our deadline. So after rolling it thru its cycles a million times times looking at its bad geometry there was about a .150 range of pushrod that gave it its "best" bad geometry. I put a dial indicator on top of the retainer and repeated rolling it thru in .025 increments. surprisingly I found the net lift varied from about .745/.750 to .785 or so, I went with the length that gave me the most net lift FWIW, Smitty
The 90 degree comment is that valve train doesn't run 90 degrees anywhere. It's always off. Adjustable pushrods and sweep will get you where you need to be and then order lengths. It will change running anyhow I find.
I kind of wondered if maybe a backset rocker would work properly with my AFR heads (they’re a v2 head casting so their rocker stud flaw was fixed). I could never get the mid lift method to work - the witness mark would end up too far on the exhaust side and the pushrods too long. I’d also get gross lift numbers that were inconsistent. When everything went together and I ran them, the valvetrain was really noisy. After trying to adjust them a couple of times, I had no change - at first I thought I had lifter problems caused by excessive spring pressures (Crane tall body), but when I dug into it and searched for similar experiences with these heads and the mid lift measuring, I remeasured everything the old fashioned way - end up shortening everything about .050 and boom! - quiet valvetrain (for a BBC).
| All times are GMT -5. The time now is 02:20 PM. |
