Steering
I currently have a full hydraulic single ram Zeiger steering setup. Has anyone gone from single to dual and if so , was there an improvement ?
I am running in the high 80s in a 22 deep v. Over 85 and I am chine walking a bit too much. Running a Labbed Bravo 1 prop. |
Can you move your drive back and forth at all? I have twins so the set up is different but when I try and move the drives by hand they don't budge at all. If yours is the same I don't see adding another ram as your solution. I've been told to check for a "hook" in the last 4-5' of the bottom. It could be 85 in a 22' foot boat is the limit :D
No , it’s nice and tight. I’ll get it figured out
At 85mph, I would add a second ram. Not saying it will help with your chine walk issue though.
Originally Posted by Griff
(Post 4863296)
| All times are GMT -5. The time now is 08:48 PM. |
