-   -   Transom housing (https://www.offshoreonly.com/forums/general-q/378918-transom-housing.html)
boatnt 04-13-2023 12:28 PM
Transom housing
Helping a buddy rebuild his transom assembly , the housing has some corrosion up by the swivel shaft seal, cleaned it up and now I am able to put the new seal in by hand anyone run into this? I hear it's kind of a common issue because the seal gets stuck on the pin, and as it turns it wears into the housing, any tricks on fixing it. Thanks.
Joeyboost 04-18-2023 02:34 PM
Not sure how bad yours is but I was getting water in the boat and I found the pin seal was leaking. After I totally disassembled it and blasted it I quickly realized it was JUNK. 4K later I ended up buying a complete new HP assembly.
https://cimg7.ibsrv.net/gimg/www.off...3fbad5c2fa.jpg
https://cimg8.ibsrv.net/gimg/www.off...be38868e41.jpg
https://cimg9.ibsrv.net/gimg/www.off...8fd73a9e85.jpg
j272 04-18-2023 03:23 PM
If it's loose on the outside... glue or marinetex it in
boatnt 04-18-2023 04:59 PM
It's not junk, it's actually in mint condition. Other than that one spot right there, the seal goes in, but it's loose. I can put it in with my hand and pull it out.
Joeyboost 04-19-2023 09:31 AM
Yeah thats a big money savings if you can fix that. My assembly looks like it came off the titanic.
cheech 04-19-2023 12:36 PM
JB Weld the seal in?
Bondo 04-20-2023 06:58 AM
Ayuh,..... If you can get at it with a prick punch, I've tapped a few divots in bearing/ seal seats, which shrinks the diameter enough to hold a bearing race/ seal,.....
