Wiring Diagram for Trim Sender Unit
Does anyone have the instructions for Trim Sender Unit 863187A2? I am looking to see which what red, blue, white are, thinking red is 5v but unsure what is ground, and signal ? I just need the function of each wire as I am wiring this into my standalone engine / digital dash.
https://cimg8.ibsrv.net/gimg/www.off...3503aeaca8.png Thanks, Nick |
when i did a search for that part number it shows its used on the following:
i have a manual for the XR with ITS and it shows that plugs into a control module and doesnt give function of wires... |
Red is +5 volts
White is signal Blue is ground |
Originally Posted by Got Freedom?;[url=tel:4867356
4867356[/url]]Red is +5 volts
White is signal Blue is ground thanks! |
If your trying to connect it to a analog gauge then you need the Merc digital to analog converter. I tried this a few years ago and the box doesn't work
From my notesThe old part 845060A1 is the old kit which is no longer sold. The new part is 884359T1 which is the same as the old part but does not have the screws and spacers. |
| All times are GMT -5. The time now is 11:46 AM. |
