Holley EFI guys what alternator and how to wire it?
Good afternoon guys,
Question I am installing Holley HP EFI with a new 4150 flange multi-port intake on my Baja 252 with a Big Block 509, I am curious what you guy's are doing for an alternator and what's the best way to wire it? I rather not use any of the old MEFI 1 harness as it is old and not in the greatest shape. |
One wire alternator that goes on the starter terminal.
GM marine 1 wire to the... I don't remember where I terminate it at. I'll look into that. Either at the battery or starter.
I'm using a 140 Amp internal regulator alternator. I had it wired as a 1 wire for a while, but changed it to 3 wire to get more voltage at idle, if I turned the stereo up too loud it would shut off because system voltage went lower than 12.5 volts. With it wired as a 3 wire it knows the system voltage, and can up the charging when needed.
Main cable goes to the starter, F terminal to ignition, jumper from positive post to R terminal. |
Straight to the starter (bottom) terminal... same as the fuse.
https://cimg8.ibsrv.net/gimg/www.off...382cdcc30d.jpg I had that wire custom made somewhere. |
Anyone have a part number on the alternator? I want to order it today. I want the 140amp I do not want to worry about amperage output.
I currently have a summit brand SUM-810344, not really "marine rated" but works just fine for me so far (I would imagine it would get more wet under the hood of a car than under my hatch anyway).
Originally Posted by LakeHuronPower
(Post 4868952)
Oh yeah...well the boat still hasn't exploded yet either!
(Post 4868954)
(Post 4868952)
(Post 4868954)
You just haven’t gotten enough fuel vapor's in your bilge yet. You have smoke detectors and etc in your house ? Fyi: only one person loses in Russian roulette. and yes I’ve seen , in person, probably five boats now engulfed in flames. |
Originally Posted by SB
(Post 4868962)
Do yourself , and your passengers, a favor a get the spark arrestors , (or marine alternator itself)for the alternator. Favor is just a figure of speach.
Originally Posted by Joeyboost
(Post 4868963)
SB - All the alternators I see marine rated none of them are 100amp or more and I do not want a automotive unit in my boat for the obvious reasons. Can you recommend one so I can get it ordered and check this box?
https://www.dbelectrical.com/product...ch-140amp.html |
Originally Posted by Rookie
(Post 4868965)
I've been using these for almost 20 yrs.
Or take your marine Alt and find a local Alt and Starter repair/rebuild shop. There's one around my area that ive had them take a standard 80amp and build it to a 160 amp in the past...
| All times are GMT -5. The time now is 08:33 AM. |
