-   -   502 carb raw/open cooling system and thermostat help (https://www.offshoreonly.com/forums/general-q/379318-502-carb-raw-open-cooling-system-thermostat-help.html)
F-2 Speedy 06-07-2023 05:39 PM
Isn't that 3/8 pipe ? 1/2 pipe would be over 3/4 inch in diameter
mattyd272 06-07-2023 06:11 PM
The two that I already bought, which includes the Autozone one, are probably 1/4" or 3/8" NPT. The port on my intake manifold, and the Datcon that came out of it, are 1/2" NPT, which is indeed a little over 3/4" actual diameter.
33bajaoutlaw 06-07-2023 06:29 PM
Originally Posted by mattyd272 (Post 4869935)
The two that I already bought, which includes the Autozone one, are probably 1/2" or 3/8" NPT. The port on my intake manifold, and the Datcon that came out of it, are 1/2" NPT, which is indeed a little over 3/4" actual diameter.
1/2 sounds right. If you look at the pic of my sender (right of therm housing) it's in an adapter to fit my manifold. The sender was 1/8 pipe. It's works fine.
https://cimg8.ibsrv.net/gimg/www.off...19e324282e.jpg
Velocity941 06-07-2023 06:30 PM
Previous owner may have accidentally used the overheat alarm sender (old ones look just like temp sender).
