best aftermarket fuel cooler to replace the factory "cool fuel"
Good morning guys,
Question, I finally got my rebuilt 509 back from the machinist and prepping it to drop back in the boat. I am replacing the stock MPI fuel injection with a Holley HP system and want to upgrade the fuel system. I am running a Holley marine rated fuel pump but it will be all -AN line so I want to replace the factory cool fuel with a new aftermarket exchanger. I found the one in the link, wonder if ti is a good choice or is their a better route to go? Engine will be in the 550hp N/A range so nothing crazy. https://azspeed.com/product/high-flow-fuel-coolers/ |
why not lose the fuel cooler and just run a return line to the tank.
Originally Posted by sutphen 30
(Post 4868940)
If you run the fuel back the tank, the tank acts as the cooler. It’s much simpler.
Originally Posted by TomZ
(Post 4868973)
Yep, you’ll be fine that way.
That`s how I did mine. Got it from Mr. Cool . It`s on the return line.
I don`t see how a gas tank would be cool in the summer heat under a floor. Cool fuel makes more power and is better for fuel pumps, regulators, injectors etc etc. https://cimg4.ibsrv.net/gimg/www.off...c91befa904.jpg |
I don't see how it will heat 100gal under the floor I mean in a car there is no fuel cooler but yes it has air flow across it under the car. I would guess if your running for hours at a time at low speed where it is returning most of the fuel back to the tank it possibly could heat soak the fuel or if you get low on fuel but for the most part I dont see no cooler being an issue but I have no real world proof. I may just install one to take the "what if": out of the equation.
I used a cooler as shown above, and it works fine. I would have preferred a return to the fuel tank, but with three separate tanks, it just wasn't practical.
Steve |
| All times are GMT -5. The time now is 08:18 AM. |
