Fuel pump from Water pump style to block? >
Old 06-07-2023 | 11:27 AM
Default Fuel pump from Water pump style to block?
Can I put a 1993 Mercruiser water pump mounted style fuel pump into the older style block fuel pump boss on a Gen IV block? Is it backward compatible? Thanks
Pismo10 is offline
Old 06-07-2023 | 11:33 AM
Don't think so. The block mounted pumps are easy to find. Holley makes several versions that work great.
Smitty275 is offline
Old 06-07-2023 | 11:41 AM
F-2 Speedy's Avatar
I think the radius of the arm is different and shorter
F-2 Speedy is offline
Old 06-07-2023 | 12:09 PM
Thanks, it does not fit. Arm is shorter for sure.
Pismo10 is offline
