-   -   Oil pan and gasket issue (https://www.offshoreonly.com/forums/general-q/379702-oil-pan-gasket-issue.html)
Batmeat 06-25-2023 05:49 PM
My build is so close. I’ve been set back because of more health issues with my wife. Current problem I’m having is the oil pan and oil pan gasket. They aren’t long enough.
https://cimg6.ibsrv.net/gimg/www.off...754f81230.jpeg
https://cimg7.ibsrv.net/gimg/www.off...dafc57b98.jpeg
it doesn’t seal at all. The gasket is supposed to go over the timing chain cover and the oil pan over it. This current setup there is no seal and oil is gonna splash all over making a huge mess.
where did I go wrong? I thought gaskets and oil pans were universal for fitment.
GPM 06-25-2023 08:33 PM
GM makes Mark IV, Gen V and Gen VI, which one do you have ? you can't interchange them.
sutphen 30 06-25-2023 08:36 PM
I'm guessing you have a Gen5 block.
BillK 06-26-2023 05:42 AM
Looks like the wrong oil pan too or the wrong front cover. What is the block casting number ?
Batmeat 06-26-2023 10:52 PM
yes it’s a mark V. I’ll look at the casting number tomorrow.
SB 06-27-2023 03:55 AM
Here is the gm marine oil pan :
https://www.michiganmotorz.com/7-4l-8-2l-oil-pan
Not sure if dipstick parts come with it.
And oil pan gasket
https://www.michiganmotorz.com/fel-p...eneration-v-vi
TomZ 06-27-2023 08:23 AM
Not to change the subject but I have a question around capacity. The pan that SB listed is the 1-pc seal pan used on GEN VI 454/502 engines - the description shows eight quarts capacity, but the capacity listed from Merc is seven quarts including the filter. That seems really low considering the cooler and lines. Of course, Merc's description states that these are approximate amounts. Interesting - the previous generation specs out at eight quarts (and they use the same pan that's given in SB's post above).
I'm using these pans on my 509s but after filling up the cooler, lines (AN -10), and filter, I'm well past that point. I always run them at the full level on the dipsticks and change out about nine quarts at each change including the filter. Am I overfilling?
Any thoughts?
BillK 06-27-2023 09:04 AM
If it is a GEN 5 block then I think the issue might be the timing cover, not the oil pan. The Gen 5 & 6 covers go back further and have a groove for the oil pan gasket to fit into. The front cover he has is for the MK IV engines. I don't think there is any way to make it work.
BillK 06-27-2023 09:16 AM
Here is a link to a Gen ^ cover on Ebay. It shows you the basic Idea.
https://www.ebay.com/itm/334891854460
This picture is from a Gen6 engine I have here at the shop. Not pretty but you can see how it sits.
https://cimg1.ibsrv.net/gimg/www.off...239ea7d613.jpg
Batmeat 06-29-2023 11:32 AM
https://cimg6.ibsrv.net/gimg/www.off...abfb1432a.jpeg
Here’s the casting number. Gota look it up when I get a second
Im betting a need a different timing cover.
BillK 06-29-2023 11:47 AM
10114182 is a Gen V Mercruiser number (among other applications) In which case I think your oil pan is correct but the front cover is wrong. I have not seen many Gen V's but I dont think I have ever seen a 1 piece rear main seal crank engine with that type of front cover.
Batmeat 06-29-2023 07:01 PM
yep I ordered a different cover. Glad it’s the cover too. oil pan is way more $$$
