-   -   Ferrea valves (https://www.offshoreonly.com/forums/general-q/379750-ferrea-valves.html)
F14A water jet 06-29-2023 08:54 PM
Ferrea valves
Gen V 489 big block, normally aspirated 600hp.
I am planning on using Ferrea Super Alloy P/N F2120P for my exhaust valves...OK?
What stainless steel is recommended for intake?
Thanks!
Griff 06-30-2023 01:15 AM
Super Alloy definitely will be ok for exhaust valves
F14A water jet 06-30-2023 07:39 AM
Thanks! I am also trying to get the RIGHT part # to order (both inconel exhaust and ss intake)?
TomZ 06-30-2023 08:56 AM
Tom,
Your machinist really needs to verify the specs for the valves. Are they stock sized or did the original builder make changes (length, stem thickness, head diameter)?
The information may be in your build sheets, but I’d verify what’s needed with your builder.
GLENAMY 242SS 06-30-2023 09:06 AM
If buying from mfg and you are a Vet. they give a healthy discount. FYI
TomZ 06-30-2023 09:13 AM
Paperwork shows 2.25 and 1.88 intake and exhaust valves, respectively. Probably stock-sized but have your guy verify the lengths and stems.
c0ncEpT 06-30-2023 09:14 AM
Super Alloy is the Ferrea Inconel material. It's a great choice for a marine application.
TomZ 06-30-2023 09:39 AM
Tom, another consideration is availability. You may find that you'll need to hunt down what you need. If I recall correctly, your machinist likes to use REV (perfectly fine). You might want to have him looking for suitable candidates.
GLENAMY 242SS 06-30-2023 09:54 AM
Tom,
Why are you looking for valves?
Gary
(PS I know you are a Vet I put that in for other readers info.)
F14A water jet 06-30-2023 10:10 AM
Originally Posted by TomZ (Post 4872052)
Tom,
Roger that...I have sent the same request to the machine shop, Thanks!
Ps-Happy Birthday!!!
