-   -   500EFI Whipple rich running condition (https://www.offshoreonly.com/forums/general-q/379772-500efi-whipple-rich-running-condition.html)
MWhitney 07-08-2023 08:54 PM
Originally Posted by F-2 Speedy (Post 4872666)
Yep, at LOTO its not uncommon to have a long idle out to main channel, what heat range are those plugs
They are heat range 8.
If this is the way theyre supposed to run, id like to find someone who can better tune these MEFI3 ECMs.
Id rather have it run clean and maybe add a wideband to monitor with less fuel.
I also noticed that both motors are set at 12 degree base timing, where the Whipple manual says 8.
F-2 Speedy 07-09-2023 09:37 AM
8* of timing is correct, adding O2 sensor's is a good idea.........I went from #8's to heat range 7 and it seemed to help, where are you located ?
MWhitney 07-10-2023 01:48 AM
Seattle area.
would you recommend scaling back to 8 degrees?
SB 07-10-2023 04:23 AM
I’m Noting , not telling…..8* recommended in Whipple’s 500EFI Install directions
https://whipplesuperchargers.com/ind...tachment_id=41
F-2 Speedy 07-10-2023 10:31 AM
Base timing needs to be set @ 8* and let the computer do the rest, what are you using to look at codes and timing ?
MWhitney 07-10-2023 12:01 PM
Snap on timing light
I do also have the Techmate tool.
I will re time them to 8 degrees.
do I need to do anything in the computer to tell it that I’ve reset timing? I see there’s a base timing mode, not sure how that works?
thank you for all your help!
F-2 Speedy 07-10-2023 12:08 PM
Yes, you need to put it into base timing mode......you will hear the engine rev up a bit, set to 8* then remove it from base timing mode
MWhitney 07-14-2023 10:44 AM
wouldn’t you theoretically want to go to a heat range hotter if plugs are already fouling? Going down a heat range, on paper, would be worse?
F-2 Speedy 07-14-2023 11:40 AM
In the NGK world lower the # the hotter the plug
