-   -   496 MAG camshaft code (https://www.offshoreonly.com/forums/general-q/379879-496-mag-camshaft-code.html)
nickyfregs 07-12-2023 05:50 AM
I have been getting an on again off again error 1051-6 camshaft synchro error. Hasn’t effected anything except the intermittent beeping is driving us crazy. My motor is a 2004 serial number OW003051. I know from researching this mercury used a few diff sensors around this time. Is there anyone that can tell me if my particular motor has the latest sensor so I can order a new one? I found a guy on FB that sells previous versions of the sensor that will work without replacing all the things Merc wants replaced to work with the new one but am hoping i can swap out with the latest one.
thanks in advance
Ryan00TJ 07-12-2023 08:01 AM
Look at TC cover. Flat=early. Extended=late
https://cimg7.ibsrv.net/gimg/www.off...fced671b9a.png
87MirageIntruder 07-12-2023 09:00 AM
You have the latest 2004 and newer sensor. I have a 2004 0W001299 and it is the newer sensor.
Tip: You can get a genuine AC Delco (GM) sensor for a 2004 and newer vehicle like a 3500 truck for much less $.
nickyfregs 07-12-2023 09:12 AM
damn what are the odds yours rolled off right when mine did, thanks brother appreciate it
