Belt driven fuel pumps
Anyone using these. they look pretty bullet proof. I am still struggling finding a good fuel pump solution. Not afraid really of the cost, just want what is best for my engines. 700 plus NA.
*10 from tank to filter then #8 to rail with #6 direct return to tank. here is what i was looking at https://www.kse-racing.com/shopexd.asp?id=34 |
Why a $1000 pump for a 700hp N/A application? That`s overkill.
What is so hard on finding a fuel pump ? Theres a lot of options. I run a 2 stage Holley. Works great , second stage kicks in after 2psi. |
Originally Posted by ICDEDPPL
(Post 4873871)
(Post 4873871)
I would just put a good electric pump on it and be done with it. Weldon or Aeromotive. You could always carry a spare if for some reason you don't think they will be dependable. Can probably swap one out in 5 minutes.
Originally Posted by snapmorgan
(Post 4873900)
1100A is the one I have always used. I have used it on both EFI and carb setups from 700hp to over 900hp. It is quiet, works great and I personally have never had one fail.
i agree we run a mechanical holly hi performance nothing fancy on 800hp na carbed no issues at all keep it simple!
You don`t need a 2 stage .. I have blowers, I need more fuel
https://www.holley.com/products/fuel...in-line_pumps/ |
Thanks guys for the advice. Hard to believe how long some of us have been on this site. Crazy. i do appreciate the input. Just have a ton of money in mu new builds and want it right.
| All times are GMT -5. The time now is 10:35 AM. |
