Water pump cap/block plate
Anyone know if I can just cap off the the fuel pump attachment to the water pump? Going electric fuel pump delivery. I’m assuming I can put some crank case oil in it then cap it with a plate.
https://cimg0.ibsrv.net/gimg/www.off...9598d0fcf.jpeg |
Yes you can. I would use gear oil, like Bravo1 gear lube. There are roller bearings in there pressed onto the pump shaft.
Awesome! I figured I didn't even think about using the Bravo 1 gear oil. Thanks you guys!
| All times are GMT -5. The time now is 02:01 PM. |
