-   -   Mercury 450R Oil Leak (https://www.offshoreonly.com/forums/general-q/380218-mercury-450r-oil-leak.html)
Lawdog1 08-12-2023 02:32 PM
I'm new to the forum. Does anyone have experience with the Mercury 450R having engine oil leaking from the poppet value?
Tartilla 08-12-2023 06:46 PM
Some good Int on the 450Rs. Prop shaft has issues from cavitation. Seems they get mounted high for speed, but suffer from prop cav....and eventually the shaft breaks.
https://www.riverdavesplace.com/foru...issues.233905/
Post# 40 starts the poppet valve info. The retainer clips break..and the guts pop out.
That may be your issue.
They were $900 ea in 2021.
Lawdog1 08-13-2023 12:32 AM
Thank you for the info. My issue isn't the poppet value itself, but how engine oil is getting into the water cooling system.
