-   -   Merc 502 Serpentine Belt (https://www.offshoreonly.com/forums/general-q/380368-merc-502-serpentine-belt.html)
JetJock 08-26-2023 05:42 PM
I have some rebuilt 502's that are now 540 (ATECO did the work)
I am eating/shredding belts every week.....I spent a lot of time and money making sure all the pulley were aligned, that helped, but I noticed that maybe the NEW OLD STOCK Belts I am buying might be 20 year old belts and shredding themselves under the heat here in Texas.
Anyone have a good source or what the part number might be for a FRESH new serpentine belt?
The Merc/Quicksilver part I am referring to is :
57-861094Q
Once we made sure all the Pullies were aligned it did fix the issue or at least slowed the shredding part down, I am concerned that my issue now is the age if the actual belt is the issue.
kornegle 08-26-2023 10:55 PM
The Merc belt on my 496 Mag was dusting and squealing. I read that the continental Elite belt would stop the dusting and squealing and it did at less than half the price of the Merc OEM belt.
spazz 08-26-2023 11:00 PM
That belt looks like it is 2649mm in length. I did a quick cross and the gates belt should be
K061037
SB 08-27-2023 06:08 AM
Ran into this doing a quick search. One , of just a few, reviews says if you have a steel ps pulley on your 502mpi, this is the correct gates belt:
SB 08-27-2023 06:12 AM
Found this on here (OSO);
https://www.offshoreonly.com/forums/...i-454-mpi.html
JetJock 08-27-2023 10:22 PM
Many thanks guys! Gates belt on order.....
LakeHuronPower 08-28-2023 07:03 AM
Your alternator bracket is probably flexing at high engine speeds.
TomZ 08-28-2023 07:14 AM
Will that bracket flex? It’s more like a box that the alternator sits in. Seems pretty solid to me.
LakeHuronPower 08-28-2023 12:34 PM
If it is like mine it's just a stamped 1/4" steel bracket. I welded a support across the top of it and that stopped my belt from shredding.
TomZ 08-28-2023 12:44 PM
Where did you weld it? Got a picture?
