-   -   Overheating at FOT with whipples (https://www.offshoreonly.com/forums/general-q/380429-overheating-fot-whipples.html)
joey O 09-01-2023 12:21 AM
I have one 1 1/2 water pickup going to a single strainer feeding twin motors. Temp was always good running FOT. I installed whipple 3.3s with intercoolers and two stage pumps and now am overheating at FOT or high speeds. Once i back off temp starts to drop right back down.
Thought about restricting the outlet of intercoolers to try and feed the block more water. What are some thoughts.
dsmawd350 09-01-2023 05:13 AM
Install a second pickup and second strainer. No way I'd feed twins with one through hull and one strainer
TeamSaris 09-01-2023 07:36 AM
What he said ^
Flow is what cools the intake charge, not holding the water in the cooler.
joey O 09-01-2023 07:48 AM
I was afraid of that answer. Thank you both
