starting without tailpipes
Quick help,
I just rebuilt my motors and purchased a hardin seaward series manifold set for my 700sci's I would like to start up the engines on the hose outside the water just to make sure everything is in order. I do not want to use the old tailpipes yet due to leak issues. Would it be fine to start engines with manifolds on but no tail pipes just to run for 5 to 10 minutes on the hose? Thanks |
Ayuh,...... No problem, especially if on the ground,......
If in the hull, just make sure the drain plug is out,.... |
Could always go to hardware and grab a couple 4” elbows and short ext duct pipes. Yes sounds cheesy but it’s worked for me in the past. Couple dabs of silicon to help hold in temporally. Just sayin! 🤷🏿♂️
| All times are GMT -5. The time now is 12:36 PM. |
