454/502 magnum intake?
How much HP the stock mag efi intake/injectors supports? Want to replace my dual plane/Q-jet with efi. BBC 509cid, 510hp @ dyno.
Originally Posted by JaniH
(Post 4880782)
Originally Posted by articfriends
(Post 4880798)
Ive made 560 hp/ 620 tq in dyno trim (no raw water pump, headers with mufflers) with un modded mag MPI intakes, Ive made well over 600 with modded ones w bored out TBs., ive made over a 1000 hp with one blowing thru it I do alot with mpi throttle bodies, tunes, injectors, etc if you need any professional help or advice, pm me, Smitty
Who did you get your intakes modded by? |
Originally Posted by purple_duckk
(Post 4885797)
I have seen the MOST hp gain from MPI intakes that were extrude honed so I no longer attempt to do any runner porting on them aside from the entrys and exits, I just tell customer lets have it extrude honed. The MPI intakes best know for making really good torque, IF someone hacks the runners down too much it will NOT magically turn it into something that will carry rpms real high, it will just trade off tq and the hp gains are limited. I did exactly that to a 500 efi intake, modded it to the point for a dyno experiment where it lost far more tq then it gained HP wise but hey, thats how we learn, right? |
Does anyone have the port dimensions of intake, where it meets the cylinder head? I just ordered a set of 290cc flotek heads, wich i think is R-oval shape. Wonder how the runners match.
Best option is to get with Smitty "Arctic Friends" as mentioned earlier. Guy is a genius with this and tried ever combo on his dyno.
Originally Posted by larose481
(Post 4887651)
https://cimg7.ibsrv.net/gimg/www.off...ad7e6e7956.jpg |
I had an ASM extrude honed one that was given to me by Haxby. It picked up 30hp over a stock intake on a very mild 540 with no other changes.
Isn't there some kind of "science" that determines ideal intake runner lengths? It seems like it has been lightly discussed here at OSO, but I don't recall anyone ever reporting that they arrived at a certain runner length through any type of formula or software. Obviously, cutting down the runner length has worked for many, but I am hesitant to drop off a lower intake with the instructions "just a little off the top".
[QUOTE=liquidlounge;4887676]Isn't there some kind of "science" that determines ideal intake runner lengths? It seems like it has been lightly discussed here at OSO, but I don't recall anyone ever reporting that they arrived at a certain runner length through any type of formula or software. Obviously, cutting down the runner length has worked for many, but I am hesitant to drop off a lower intake with the instructions "just a little off the top".[/QU
Theres a progarm called pipe max that figures out what "harmonic" a intake is happy at using cu inches vs rpms vs runner length (plus takes into account other info). a 454/502 mag intake in stock form is done around 5200/5400, add 10% more cubic inches by making it a 540, its done approx 10% sooner at 4900/5000. shorten effective runner length , you can now raise the peak rpm SLIGHTLY assuming its not restricted by something else like camshaft , etc. Thats why in my comments I mention not wasting time cutting one down and using the stock cam. and again, as "snapmorgan" mentioned and I mentioned earlier, the most bang for the buck is extrude honing, Smitty |
Pretty sure that i read where the OP has purchased a set of "roval" heads. I seriously doubt that the intake will be a restriction and no amount of porting is going to help the situation. Maybe gasket matching the intake ports of the head to the dimension of the intake and maybe cutting the tops of the runners down level with the floor of the upper might help a little.
Say why and 🤣 just came from shopping. Going to weld injector bungs and convert this to efi. Wonder if 2x 1000cfm throttle bodies are too much, or should i convert the upper for single 1 barrel?
https://cimg8.ibsrv.net/gimg/www.off...e700ab5cd7.jpg https://cimg9.ibsrv.net/gimg/www.off...f3a4eed183.jpg |
[QUOTE=articfriends;4887711]
Originally Posted by liquidlounge
(Post 4887676)
(Post 4887676)
I have. Do a search under my name and pipemax. It was for a 502cid engine.. |
Originally Posted by SB
(Post 4887764)
Yup.
I found SB's post from 2021:
Found a 502 with max power 5600rpm I had run into pipemax: @ 5800 RPM - Induction System Tuned Lengths = ( Cylinder Head Port + Manifold Runner ) 1st Harmonic= 35.485' (usually this Length is never used) 2nd Harmonic= 20.140' (some Sprint Engines and Factory OEM's w/Injectors) 3rd Harmonic= 14.061' (ProStock or Comp SheetMetal Intake) 4th Harmonic= 11.067' (Single-plane Intakes , less Torque) 5th Harmonic= 8.979' (Torque is reduced, even though Tuned Length) 6th Harmonic= 7.554' (Torque is reduced, even though Tuned Length) 7th Harmonic= 6.520' (Torque is greatly reduced, even though Tuned Length) 8th Harmonic= 5.734' (Torque is greatly reduced, even though Tuned Length) Note> 2nd and 3rd Harmonics typically create the most Peak Torque 4th Harmonic is used to package Induction System underneath Hood Plenum Runner Minimum Recommended Entry Area = 2.865 to 3.223 Sq.Inch Plenum Runner Average Recommended Entry Area = 3.294 Sq.Inch Plenum Runner Maximum Recommended Entry Area = 3.365to 3.981 Sq.Inch Minimum Plenum Volume CC = 1113.7 [typically for Single-Plane Intakes] Minimum Plenum Volume CID= 68.0 [typically forSingle-Plane Intakes] Maximum Plenum Volume CC = 8229.2 [typically for Tunnel Ram Intakes] Maximum Plenum Volume CID= 502.2 [typically forTunnel Ram Intakes] SB is offline Report Post |
SB: on your program that measurement is from port open to valve opening, correct?
3rd Harmonic= 14.061' (ProStock or Comp SheetMetal Intake) |
Just measured the runner lenghts, head 5.5"+manifold 8"=13.5". Weiand 1985/5985 intake. Meausured head is gm iron oval, dont have the floteks home yet. floteks have a different intake valve angle, so that may vary a little compared to the gm iron head
https://cimg9.ibsrv.net/gimg/www.off...f603030e0f.jpg |
| All times are GMT -5. The time now is 09:07 PM. |
