-   -   Big block mercruiser V-belt pulley replacement (https://www.offshoreonly.com/forums/general-q/380724-big-block-mercruiser-v-belt-pulley-replacement.html)
Joeyboost 10-02-2023 08:59 AM
I am looking to replace the stock V-drive pulleys with a new set of quality polished pulleys. I see Hardin has the their own setup but my water pump pulley is 3 rib using only 2 but this kit only uses one. The sea pump only goes off the crank where the alt and PS wraps around the water pump & crank.
https://www.hardin-marine.com/p-1385...ation-5-6.aspx
