Would it be worth it?? Exhaust swap
So I have been doing a lot of reading on exhaust systems as I'm always looking for upgrades on things...I have a 540 with a 14-71 blower fuel injected and I got to thinking about exhausts. I currently run CMI E-tops and they work perfectly fine no leaks or anything but I got to wondering if swapping to stainless marine gen 3's would be worth the upgrade? I have read that they are good for a power bump on engines but couldn't really find anything on if they would be a worthwhile upgrade for me or not? Looks like the kit is around 7500 bucks plus transom mods as I run 4" tips now that are dry to the tip and I would opt for either 4 1/2 or 5" tails with the new ones and would convert to the dry tip style beauty rings and gaskets on the transom vs the rubber bellow connection like I have now as I've had them fail in the past.
Could probably sell my e-tops/tails for 2kish maybe...they are powdercoated black and the tails are wrapped with exhaust wrap as I didn't want the shiny stuff on my engine...just personal preference. So basically if they sell...would be a roughly 5-6k upgrade plus all my time modding my transom which is whatever...not a big deal. What's everyone's thoughts? Worth the upgrade? |
I am not the smartest guy on here, but I would not spend the time and money to change out your CMI's. At the same time, I would probably never pay 2k for anything used CMI. The elbow tops are probably the most reliable thing CMI makes, so that's a big plus. You know more than I do about blower motors, but I do know that blower motors handle less than optimal exhaust better than HP NA motors do. AND just say you get into your 40's and say to yourself I don't like crawling in bilges anymore and I just want some nice low maintenance big blocks. Now, the 5" system is less than ideal. My vote is keep it as is.:)
Stainless Marine Gen 3 is where it's at!!
What is the ID of your current runners ? what HP ?
E-Tops rarely fail. I know of two sets that are 20 and 17 years old and still no leaks. If it ain't broke...
I doubt you’d even see a speed increase. 2k plus all the other screwing around worth it for zero speed increase?
Originally Posted by GPM
(Post 4884149)
Like I said I have no issues with the current headers at all just was seeing if I could expect a difference by switching? Seems like so far from the posts they won't make much of a difference if any? Always looking for any kind of upgrade and read reports of HP gains on NA builds by switching but wasn't sure on a SC application? Thanks for all the replies so far!! Also that OL is ridiculously bada$$ by the way!! hahaha |
OK Steward settle down.:hitfan:
The only advantage I see is easier to install . you ROI in terms of HP is extremely low here . |
LOL thanks for the insight Dan :throw::lolhit:
| All times are GMT -5. The time now is 03:04 AM. |
