Water pick ups
I'm in the process of adding water pick ups for Whipples. I can't go thru the transom so I'm going to have to go thru the bottom of the boat. My question is how to I seal everything up once I go thru the bottom? The pick ups themselves don't have a flange or anything outside the hull so once I put an 1-1/4" hole thru the bottom how do I seal up the tube sticking out the bottom of the boat? Any help (and pics) would be greatly appreciated.
https://cimg8.ibsrv.net/gimg/www.off...aa097c1ffa.jpg |
Never seen a thru hull pickup without a flange. My 43 Black Thunder has the pickup pipe hole filled and the escutcheon flange set in 5200.
Originally Posted by Topshelf38
(Post 4884425)
That seems insanely too long.
Originally Posted by ICDEDPPL
(Post 4884431)
I'd cut the hole. Then I'd resin over the cut and exposed glass. Then I'd seal the flange to the hull with sealant of choice. I'm not a fan of 5200 because of how runny and permanent it is. Maybe 4200 is thicker.
Originally Posted by Rookie
(Post 4884446)
(Post 4884425)
Originally Posted by splashandburn
(Post 4884455)
So I'm assuming your flange is on the inside of the hull, not outside?
| All times are GMT -5. The time now is 08:18 PM. |
