-   -   Bigger valves for 781 ovals (https://www.offshoreonly.com/forums/general-q/381023-bigger-valves-781-ovals.html)
JaniH 11-07-2023 01:59 PM
Is the original gm hardened seat enough for the exhaust? and if so, what size valve can be used keeping the seat hardened.
Some say you need to use additives with these old heads, and some say it is bull$$.
getrdunn 11-07-2023 05:47 PM
Need more about your build. NA / SC / HP. Not going to gain much unless you spend more on porting etc than new heads. JMO
JaniH 11-08-2023 03:05 AM
NA 502 cid, hopefully somewhere between 550-600hp. Making 520hp now @5300rpm with ported peanut heads via stock size 2.06/1.72 valves, 230/236, 0.620" lift, 112 lsa hyd roller. Going to keep the same camshaft.
getrdunn 11-08-2023 09:34 AM
What casting number on the heads?
5/16” pushrods?
Stock valves?
equals disaster but considering that’s not your question I won’t go there. However valves and seats are crucial regardless of additives etc. I know making the power with your heads isn’t a big deal but making it last is. If heads been ported im assuming they’ve been flowed? You’re about peaked out with rpm and “definitely” with lift.
Please provide casting number on heads. A little bit confusing when referring to 781’s and peanut port heads. Entirely different. Just sayin
JaniH 11-08-2023 11:25 AM
5/16” pushrods?
Stock valves?
Current heads are 360 casting peanut heads with 2.06/1.72 ferrea 5000 series valves, these heads have exhaust seat insert from the factory. Considering to replace the peanuts with 781 casting, but i quess the gains are minimal without stepping up in valve size, atleast in the intake side. 360 castings flowed around 280cfm @ intake, 205 cfm exhaust without pipe and the port it self is barely ported, just slightly radiused short turn, most of the gains came from chamber work and the valve/seat. I think i could make the 781 exhaust better than the current 360 with the same 1.72" valve, if truly port it. From my understanding 300cfm intake flow should be easy with bigger valve and some porting. The cam has 6 degree split so it might stil work without massive exhaus flow gains, maybe.
getrdunn 11-08-2023 02:13 PM
The flow ratio is decent for GM heads. I remember GM heads always liked a bigger split (10-12 deg + -) due to the poor exh etc. If you have a good reliable package I’d call it a day unless you go aftermarket otherwise your gain going to be so minimal I wouldn’t think would be worth all the time, effort and expense. JMO of course.
JaniH 11-08-2023 02:55 PM
These 781 i have has fresh mint condition bronze quide liners, so installing seat inserts for the exhaust would not broke the Bank, but in other hand i can get 290cc flotek ovals 1500$ pair and go from there. Wonder what kind of power those floteks would make with my cam and what rpm? Quess some where in 5600rpm, that might be over the limit of the gm dogbone hyd lifter.
snapmorgan 11-08-2023 02:58 PM
I wouldn't spend any money on an old set of GM oval ports trying to make power. The aftermarket stuff is so far superior that it just doesn't make sense .
JaniH 11-09-2023 11:28 AM
You are right! I just need to take a account my hole combination of parts. The gm roller lifters might be a problem at higher rpms with max recomended spring pressures 140/380lbs , 230/236 @ 050" cam might pull quite high with good set of heads.
snapmorgan 11-09-2023 12:51 PM
I have ran the dogbone lifters with 450# over the nose at .635 lift at 7000 rpm in a boat engine with no ill effects.
JaniH 11-10-2023 11:39 AM
Ok, then i should not be worried, if you are talking about stock gm lifter wich is found from zz502 and lower hp bbc crate engines.
snapmorgan 11-10-2023 01:10 PM
Yes, the stock GM performance dogbone lifter.
Tartilla 11-23-2023 01:26 AM
Floteks are a great marine choice. They have powdered metal seats.
I normally don't like powdered metal parts. Like the new S&W powder metal hammer etc.
But the tech in the powdered seats is really great. The powdering and pressing + baking enables alloys that normally would not mix. They are softer to start, and work harden in use.
The 290s flew really well. Eric Weingartner racing on youtube has some good flow vids and reviews.
JaniH 12-09-2023 04:19 AM
Cool videos! helped me alot to choose the floteks over the old iron 781. Floteks are on their way to Eeurope.
