-   -   solid roller vs hyd roller profile comparison (https://www.offshoreonly.com/forums/general-q/381045-solid-roller-vs-hyd-roller-profile-comparison.html)
94sylvan 11-11-2023 01:08 PM
Anyone made the switch from hyd roller cams to solid roller? looking for comparison numbers on duration to avoid reversion.
underpsi68 11-11-2023 01:28 PM
What about solid roller lifter on hydro lobe?
94sylvan 11-11-2023 04:54 PM
I've thought about that as well with a tight lash ( .004 - .006) but hydraulic lash ramps are pretty aggressive because they can rely on the hydraulic cushion to moderate the initial hit. Once a solid starts opening, they have much higher open rates than hydraulic, thus the 20 plus degrees duration more @.200 lift that i wouldn't take advantage of with a hydraulic profile.
Tahoe540 11-12-2023 07:58 AM
I have run solid lifters on a hydraulic roller for a season. I played around with lash from around .004-.008 just to get it as quiet as possible. Replaced solids with some Johnson hydraulic's last season with no issues to the cam that I could see.
underpsi68 11-12-2023 08:12 AM
I ran 2 hydraulic roller cam lobe cams with solid rollers. Both were custom for me. It all depends on the lobe. It is best to contact the cam manufacturer and get their advice, if you can do it or not. Both were 010 lash. If the lash is too tight, the valves can hang open when cold, not good.
One of my friends with a turbo sbf installed solid rollers on his comp cam. Comp said np. He picked up .3 and 3mph in the 1/4 mile with it.
getrdunn 11-12-2023 09:30 AM
I love my SR’s (inverse radius lobes) from mike jones (jones cams) for my 565’s. They pull extremely hard, easy on valvetrain and sound BA. Many including myself have run solids on hyd rollers with success but I wanted to go a different route this time and very happy.
hogie roll 11-12-2023 04:06 PM
What are the specs?
Rookie 11-12-2023 07:40 PM
I've run solids on my HR lobes since '06 my builder has done it for 30 yrs. Also spoke with Comp and they said no problem and with their HUC lobes it's a good combination.
94sylvan 11-12-2023 07:53 PM
Originally Posted by Rookie (Post 4884913)
I've run solids on my HR lobes since '06 my builder has done it for 30 yrs. Also spoke with Comp and they said problem and with their HUC lobes it's a good combination.
When running solids on a hyd profile, what do you do with spring pressures? The solid roller is lighter, but your still a cast cam so you can't get too crazy with pressures.
underpsi68 11-12-2023 08:36 PM
Higher pressure on solid lifters.
I would only run 8620 core, if possible.
