Originally Posted by PQ290Enticer
(Post 4885483)
Ill check the ground connections but im pretty sure they are good. If the solenoids are working (clicking) when i turn the key that means the ignition switches are good?
Also if the bendix hits flywheel but the teeth don't engage (bad starter alignment), the solenoid won't reach end of stroke to power the starter motor. I've seen where the wrong bolts were used to mount the starter and the starter eventually shifted itself out of alignment. The knurling of the starter bolts should eliminate any side-to-side slop between the bolt and the block and also between the bolt and the starter. If all that's correct, the starter shouldn't budge (assuming the bolts are tight). I've run across a situation on my boat where a "metric" starter was used. Hole in 454 block was 3/8" and hole in starter was 10mm. In that case, a special bolt was needed that had half of the knurling at 3/8" and the other half at 10mm. "Stepped knurling" if you will. An old solenoid with burnt contacts (for starter motor) will behave the same but since yours are new, I'm ruling that out. |
You might try taking out a bolt at a time and sanding the under side of the bolt head and the surface around the bolt hole.
Originally Posted by TomZ
(Post 4885491)
With that said… double check grounds, too.
A good heavy grease on clean connections will prevent a lot of corrosion, and issues down the road. |
I replaced the neutral safety switches maybe 4 or 5 years ago. The ignition switches are original from 1995. I had the Marina install the engines and do the alignment but i did everything else so i may have a wire or several wires that have worked loose. I have time so i guess a complete nut and bolt check is in order. Thanks for the help
Also check that the wires are tight in the crimp ends. That one has got me before.
Originally Posted by f_inscreenname
(Post 4885541)
Originally Posted by Tartilla
(Post 4885506)
Electrical grounding often gets overlooked both on troubleshooting and maintenance.
(Post 4885545)
I have an "Electric Dielectric Grease" that I use on a lot of area's but I know I didn't use it on any of the ground locations. Probably in hindsight that might have been the place to use it?
Originally Posted by underpsi68
(Post 4885550)
Dielectric grease is non conductive. I would not use it there.
https://cimg2.ibsrv.net/gimg/www.off...c1e3da500a.jpg https://cimg3.ibsrv.net/gimg/www.off...f9f826d899.jpg |
You’re fine with the dielectric. It will reduce corrosion.
| All times are GMT -5. The time now is 04:28 AM. |
