Bullet 540
Your engine build/specs will help determine carb size but if it’s a 540 I would think a 2 circuit 1050 would be a better option but in reality you can make almost any carb work with some work. The real kicker is are you certain you have a stroker 540? Any machine or speed shop can determine that for you. I’m not trying to insinuate anything just being honest. You’ll get it worked out as long as you use a reputable shop in your location. Good luck and keep us posted.
in this time the engine is at my engine builder .. y change the valve seal . And y look what cam and spring y have . After this y go to dyno and give you somme news .
I’m assuming it’s a std 9.8” block. Merlin does indicate it’s an aftermarket block. Your bore and crank size will confirm your CI. How long before your engine builder gets it in the dyno? Snap was right - do we dive into all the bs and start investing or strap it on a dyno and see what she’s got!!! Cut to the chase! 😂
this boat was in my area depuis 2006 . A talk to a few guys we have it … one off this say me we turn at 5800rpm whit the same engine .. same blade and it 80mph … the guys we add boat bettewen me and other guys rebuilt the engine …. If it change something in the engine and kill the rpm ..? This is why y go on the dyno
I will go to dyno soon , my engine guys call me and says me my valve spring are bad . Call new one putt on it and go to dyno .
It’s tell me the spec off the cam .
641-667 lift
242-254 @ .050
What are you thinking ?
641-667 lift
242-254 @ .050
