-   -   Bravo I Prop ?? (https://www.offshoreonly.com/forums/general-q/38153-bravo-i-prop.html)
Donzi38ZX 12-03-2002 01:09 AM
Bravo I Prop ??
I am looking for some help with my props. I have a 2001 Donzi 38ZX with HP500EFI. When I tested the boat it ran 75MPH on GPS at 4900 RPM WOT. The props are Bravo I 4 blade 28P, they are not labbed, drives are 1.5 Bravo One XZ. Mercury Racing said they could lab the props and I should pick up 300 RPM of course no guarantees. They also said optimum RPM at WOT would be 5300. Anyone see similar results from labbing props and what effect on cruise speed and top speed. Any info on prop shops other than Mercury and what I should expect to pay? Also any info on turning these in or out? Thanks for the help.
Steve
HOUSTONPROP 12-03-2002 02:24 AM
labbing props
sometimes I see a huge difference in speed changes and other times very little or none, but accleration has always been reported better,sometimes it takes more than once to get the prop or props where they need to be .with my shop I will do what it takes to get it there or will work something out where you will be happy no matter what. ask and look around.the fee to lab the 4 bld normaly at my shop is 300.00 plus 12.50 shipping back /right now we are running a special to lab a four bld for 175.00 if I can help out in any other way please post or e-mail me your phone and the best time for me to call you.let me know. :) teambajamarine prop host
audacity 12-03-2002 04:07 PM
i may know a few that has some seat time in one of them there donzi boats....your in IN so when you actually have water and can test let me know i'll hook ya up with the right people.
Donzi38ZX 12-03-2002 04:13 PM
Audacity
Audacity,
Thanks for the offer. Now can you do anything about all this *&%$^$#! ice. :D Spring seems so far away.
Steve
audacity 12-03-2002 04:19 PM
yeah!!!...it's called key west brother!!!i think you should head down with all of us! 20th-5th or something like that...actually when we're not down in FL testing....i go WAY north and ice climb...so our location is not all bad:)
Donzi38ZX 12-03-2002 09:37 PM
Unfortunately I can't get the time away. Would it make sense to have the props looked at in the offseason?
Steve
HOUSTONPROP 12-03-2002 10:12 PM
NOW'S THE TIME
Steve
HELP ME!!!!! HELP YOU/ I have lowered the prices to stay busy thru the winter months and that we are,but the work is backed up in june /july or whatever/thanks DARIN:KEYWEST:cool:
Donzi38ZX 12-03-2002 11:44 PM
Darin,
The price looks great and I have read some good reviews of your work. I am just not certain if I should start with prop work or need more info. I just purchased this boat and the only numbers I have are from the sea trials when purchasing (2-3 hours). Have you finished props for this boat before? If so, what results did you see. The 38ZX is a heavy boat at 11,500 lbs dry.
Steve
MrCIG 12-05-2002 09:05 AM
Steve,
Knock the snow off and put it in the water.
It's cold enough to pick up 2 miles an hour.
You can call Jerry at Air Marine they are across from Midway air port. He is a Mercury Prop dealer. He also has demo props you can try.
Did they get it put on the trailer yet?
see ya Saturday
Mark
HOUSTONPROP 12-05-2002 11:39 AM
bravo props
no,I havent worked in bravos for this setup. look under tech/Q&A there is some discussion on bravo one props/ balance ect. but now is the time and nothing else they need balanced /I will alway's make any changes for you in the summer if needed at no cost to you. its up to you though.thanks DARIN M;)
audacity 12-05-2002 01:04 PM
Houston, how do you measure your props?
HOUSTONPROP 12-05-2002 07:38 PM
measurment's
:cool: we'll I use pitch blocks,pitch &rake indicator ,I can use a computerized propscanning machine when and if need and my eyeballs,and a tape measure and also my thumb.:D :D and it's a good honest question with a good honest answer/not trying to be :rolleyes: :rolleyes: :)
BryanTuvell 12-07-2002 01:10 PM
Try these folks
www.throttle-up.com
