Ccw rotation bottom mount starter p/n? Mercrusier
As the title suggests I need the part number for a Merc (5.7) Reverse Rotation (RH) BOTTOM MOUNT Starter.
Any help greatly appreciated, Thank you |
Your title is a little confusing because CCW usually refers to a "normal" rotation engine. Reverse rotation is considered CW. Engine rotation is stated when looking at the flywheel end.
A 'normal" car or truck V-8 would be considered CCW rotation. If you are looking at the front of your engine which way does it rotate ? |
Thank you for your input and you are correct about engine rotation, however, as for starter rotation ccw is for a reverse rotation engine.
I should have stated a reverse rotation engine for clarity, oh well. Anyway I figured people on here would understand a standard rotation situation would be a breeze, I found a reverse rotation one on Hardin only to find they no longer carry it. I was able to track down exactly what I needed after a day on the computer it is on it's way.. Thank you for your clarification.. |
| All times are GMT -5. The time now is 11:22 AM. |
