What Outdrive do I have?
It is currently on a 79 pantera 24' -- not sure if it is original or not.
It has Mercruiser 330 on the out drive. its paired up with a 454 330hp motor. Basically i need to know what i have -- and what it will take as far as hp. I am looking to build up to a 550 hp motor (possibly a whippled 625). What will this drive take stock? what drive should i be looking at? what drive will work with this transom assembly? Is there anywhere that lists drives and what max hp they can handle? I see several alpha 1's with transoms fairly cheap and some bravo 1's in my range also. thanks Mark |
Could be a TRS,do you have a transmission inside the boat? If it's a TRS then the cutout will be too big for a alpha/bravo. If it's a TRS then you could put a speedmaster three drive on it.
Probably a TRS if it's original. See if you can find a serial number on the drive to confirm. I've seen a lot of TRSs live a long time at around 500hp.
Forget about an alpha, thay're only good for 270-300hp max. The TRS is also stronger than the bravo, but TRS parts may soon become hard to find. See what kind of tranny it has. If it's a B/W velvet drive, 550hp shouldn't be a problem. Gary |
Being a 79, it probably has a TRS with a MercTrans tranny. that will be your weak link. (the tranny)
Good luck, Kurt. |
jeffs whippled 454 huh???
yup -- possibly jeff's!
OK -- i'll see what more information i can find -- i have the boat out at a friends house -- so its kind of a hassel to go look at it right now. Should be in the new house in a week or two -- makes things much easier! |
| All times are GMT -5. The time now is 02:29 AM. |
