7.3 Godzilla marine application
Just curious what is being used for exhaust manifolds?
Where have you seen it in a marine application?
Yeah...there isn't a 'mainstream' manufacturer offering the Godzilla for marine use.
Just curious what is being used for exhaust manifolds? :food-smiley-007: |
Would be nice to have a modern larger cu in motor available.
My bet is that the Godzilla is coming in marine form at the OEM level, but most likely for wake boats and not I/O's. Someone like Hardin marine has already considered and may even be developing some conversion items. If GM is still doing 8.1's (I am assuming they still do), then how much better would a Godzilla be? We have already seen that the LS motors start out at a disadvantage in a boat because of the cubic inches deficit. The Godzilla is basically a bigger LS, but "only" 7.3 liters.
GM sold the rights for the 8.1 to PSI engine Co.
Originally Posted by 87MirageIntruder
(Post 4898348)
It may be on the cutting room floor at this point. That being said, there are some amazing BBC aftermarket heads that give lots of potential. BBC iron block is relatively light at 220lbs bare with caps and bolts. Iron LS block is 200lbs. The PSI engines are promising. |
| All times are GMT -5. The time now is 07:04 PM. |
