Calling all Cig interior guys >
Old 05-15-2024 | 02:50 PM
F-2 Speedy's Avatar
Default Calling all Cig interior guys
So whats the trick to getting to the top mounting stud the nut came off, the 5 inch tube that carries all the wires and cables is just underneath it
TIA Speedy
F-2 Speedy is offline
Old 05-15-2024 | 03:35 PM
Can you back up a little and take a pic? Is there a panel towards the rear seat that lets you reach inside, then forward. I know some of the bolts on mine are a far reach from certain access points.
Else you just have Christmas trees holding the rest of the panel in, might be able to "open" the panel up off the cockpit wall and go between the panel and boat structure.
frickstyle is offline
Old 05-15-2024 | 03:47 PM
F-2 Speedy's Avatar
After looking closer I think I need to remove the back seat, there is an opening just above the arm rest at the rear of the upper panel .....pita
Old 05-23-2024 | 06:28 PM
F-2 Speedy's Avatar
the correct tool is what is needed..........
