-   -   Air condition weight (https://www.offshoreonly.com/forums/general-q/382678-air-condition-weight.html)
rvtransport 06-05-2024 02:02 PM
Anyone know how much dock side air condition weighs installed in the boat?
ICDEDPPL 06-05-2024 05:34 PM
What is a dockside airconditioner?
rvtransport 06-06-2024 08:55 AM
I guess I should just say air conditioning. It is factory installed in my 2009 Fountain. It has a water bump in bilge that draws from sea strainer and compressor and ducting is mounted in port side cabin. The reason I ask is my boat has a slight list to port side and figured it could be weight of AC? There is also stereo with amps in same cabinet along with seems to be very heavy counter top cabinet with sink. This is the new interior only in 2009 and 10 42 Fountains before the went under. It seems to run bow heavy compared to my previous 2006 42.
Wally 06-06-2024 09:46 AM
Depending on what size the AC system is i'd venture to guess the unit itself is between 40-50 lbs and the pump assuming its a March LC-3 is right around 6.5 lbs
rvtransport 06-06-2024 10:05 AM
That is lighter then I thought. Thank you!
