-   -   509ci Hp Guess? (https://www.offshoreonly.com/forums/general-q/382799-509ci-hp-guess.html)
FloridaMan717 06-13-2024 09:43 PM
509ci Hp Guess?
A friend and I built up a gen 6 502 a little while ago. I never was able to dyn it, but alway curious on the hp. Maybe some of you have built a similar engine and have an idea on HP. It’s in a 302 Mariah with B3 out drive and I’m having a tough time getting it propped right. Thanks in advance.
Gen 6 502 mag
- stock crank, rods
- .030 over stock pistons
- comp cam .547 lift on in and out (295-014518k)
- edelbrock aluminum heads
- edelbrock rpm intake
- edlebrock 750 carb
- 1.7 scorpion rockers
- comp lifters and custom Push rods
- MSD billet dis
- Eddie marine manifold and risers
GPM 06-13-2024 10:30 PM
About 25 HP more than stock, exactly what heads, what compression, what are the rest of the cam specs, is it happy with a 750 carb ?
Griff 06-13-2024 11:52 PM
Prob 450-475hp
SB 06-14-2024 05:11 AM
Be careful - Those carbs are calibrated for 330hp 454’s and small blocks.
And furthermore , i agree - def not enough carb for even a mild 502
articfriends 06-14-2024 05:45 AM
I see that cam has 230/236 duration at @ .050, kinda short lift. I second griffs guess at 450/475
IGetWet 06-14-2024 06:13 AM
509 or 502?
