-   -   2005 Merc 4.3 stalling (https://www.offshoreonly.com/forums/general-q/383159-2005-merc-4-3-stalling.html)
Stevetillis 07-22-2024 12:35 PM
I have a 2005 MerCruiser 4.3 MPI. The motor stalls after acceleration or when comes back to idle
The following have been done
1 computer hooked up and fault codes showing are 94 which is a Pitot Pressure circuit which can not be cleared. Don’t think this is the problem
2 changed out IAC twice and is working properly along with new screen but you can unplug and plug back up with me difference. Getting 12 volt at the plug-in
3 new fuel pump with 40 psi
4 timing set
5 Injectors cleaned
6 new dist cap rotor plugs
Any help would be appreciated
SB 07-22-2024 07:10 PM
Please explain this clearer and with more detail “but you can unplug and plug back up with me difference.”
sutphen 30 07-22-2024 09:24 PM
what are the iac counts when idling?throttle blade may need to be opened or cleaned.
