-   -   2007 Mercruiser 496 H.O Correct Head and Engine Gaskets To Use? (https://www.offshoreonly.com/forums/general-q/383222-2007-mercruiser-496-h-o-correct-head-engine-gaskets-use.html)
Thomasg49946 07-27-2024 02:08 PM
I have a 2007 MerCruiser 496 425 HP with an OM serial number prefix.
What is the part number of the correct head gaskets to use? Can you use Fel-Pro? Genuine Merc part numbers to use are?
Also, complete engine gasket kit part number?
Todd B. 07-28-2024 10:13 AM
496 gaskets
Hi, just redid a head on my 496 ho and used napa for felpro head gasket($40 compared to mercury $248) and valve cover gasket($21.95 for both sides compared to mercury over $250 for one side) and intake gasket ($109 compared to mercury $275). Get heat exchanger seals, thermostat and seal, and exhaust manifold gasket (one piece)from mercury. I have the napa part numbers if you want them. Todd
989-289-9240
