502 spring pressure
How much open pressure can GM h y d roller lifters handle,500lbs open? Under 6000 rpm
I think thats a bit much for a stock lifter, Id stay in the 400-425 range......the Isky 8005A is a good spring for a 500 525 efi rebuild, whats the cam specs ?
Cam
525 cam co u ld I run solid lifters on that cam?
I wouldn't, lobe profile is for hydo roller, why do you want to run 500 lbs springs with that cam ?
Cam
Just afraid of valve float
The rev limiter is set at 5350 on the 525 EFI 555 controller, if you want to spin it to 6k I might choose another cam
Could run a short travel hydraulic roller lifter
I’m running crower solid roller lifters on a crane 741 hydraulic roller cam which is similar to the 525 hydraulic roller cam with comp roller rockers. Lash is set @ 6.
Originally Posted by tripps
(Post 4909972)
I've run solids on hydraulics forever and when talking with Comp they had no problems and said it would be a great combination when I ordered my new HR cams. |
Is a stock 525 cam billet core ? ....:drink:
I was told by Lunati not to exceed 430# on the stock GM dogbone lifters. I have turned them to 7000rpm at just over 400# open pressure.
Joe, How many hours do you run the springs/lifters before changing.
Well Gary, I don't believe I ever had a boat long enough to find their failure point. Typically I would have a boat 4-5 years and put 50-70 hrs per year on them. Camshafts would be in the .630 lift range. I would think that 300hrs would be a good point to check them.
We're running 170lbs on the seat with 430lbs on stock 525 cams. Using johnson lifters. No issues.
| All times are GMT -5. The time now is 03:11 PM. |
