-   -   Replacement Merc 496 Fuel Rail (https://www.offshoreonly.com/forums/general-q/383827-replacement-merc-496-fuel-rail.html)
Brad Christy 09-30-2024 09:24 AM
Guys,
As mentioned in my recent “Hurt 496”, thread, I am developing an “80% drop-in” replacement for the 496 fuel rail. The end user will have to plumb them in and provide their own fuel pressure regulator. All the fixturing is machined and ready to go to black oxide (as a rust preventative), and all the components for the rails are ready to start the welding process.
Here is the teaser:
https://cimg8.ibsrv.net/gimg/www.off...8bd175081.jpeg
Fixturing components. There are four individual fixtures, each with their own place in the order of operations.
https://cimg0.ibsrv.net/gimg/www.off...553a8695c.jpeg
Rail components for two complete sets of rails. The injector cups and AN bungs are machined from bar stock. All 316ss. The mounting tabs, also 316ss, are not included in the pic, as I don't have them from the sheet metal shop yet, but will be included on the rails.
https://cimg2.ibsrv.net/gimg/www.off...59de39117b.jpg
This is the layout, looking at the engine from the cockpit, toward the transom. My plan for mine is to supply the front port side, bridge across the rear and return from the starboard from, out the top of the injector cup. This should allow for the purging of air almost immediately.
More to come.
Thanks. Brad.
Brad Christy 10-02-2024 11:57 AM
Guys,
https://cimg0.ibsrv.net/gimg/www.off...ba2af50ed.jpeg
The gang of fixtures.
https://cimg1.ibsrv.net/gimg/www.off...ddd2502cf.jpeg
The final assembly welding fixture, with mock-up in place
This thing is coming together.
Thanks. Brad.
Brad Christy 10-18-2024 04:56 PM
Guys,
https://cimg7.ibsrv.net/gimg/www.off...9556edfa0.jpeg
https://cimg6.ibsrv.net/gimg/www.off...b361d527d.jpeg
https://cimg1.ibsrv.net/gimg/www.off...0ff965ec3.jpeg
https://cimg2.ibsrv.net/gimg/www.off...2b3f1e0ae.jpeg
https://cimg3.ibsrv.net/gimg/www.off...8440a1768.jpeg
https://cimg8.ibsrv.net/gimg/www.off...d7a371181.jpeg
Starboard side rail is done, less the AN fittings to be welded on. The welder buddy has Fridays off, and he’s otherwise engaged both weekend days, so progress is slow. We ran out of time for today, but the injectors are in place. I’ve made up some injector cup plugs that are held in by the same clips that hold the injectors in, and we will be doing a pressure test on the rails as soon as the AN fittings are on.
Thanks. Brad.
Brad Christy 10-18-2024 06:21 PM
https://cimg6.ibsrv.net/gimg/www.off...79e698310.jpeg
https://cimg7.ibsrv.net/gimg/www.off...45640aec7.jpeg
Port rail.
Thanks. Brad.
boostbros 10-18-2024 08:11 PM
for those of you that don,t know a volvo 496 fuel rail is superstupid priced i think it was 5 or 6 grand
Brad Christy 10-18-2024 08:52 PM
Boost,
Seriously….?
My nephew sent me a link for one. And you’re right. They wanted $5500 for it. I thought it HAD to be a joke. The link is down now, so, I guess SOMEBODY was that desperate.
Thanks. Brad.
Brad Christy 10-19-2024 12:57 PM
Guys,
https://cimg4.ibsrv.net/gimg/www.off...4b1a9cf21.jpeg
https://cimg5.ibsrv.net/gimg/www.off...7b70b25f3.jpeg
https://cimg6.ibsrv.net/gimg/www.off...3e435d359.jpeg
Close-up look at the welds. The man is an artist. But, then again, this is what he does 40-50hrs a week; all stainless and Inconel.
Thanks. Brad.
Brad Christy 10-26-2024 05:27 PM
Guys,
https://cimg8.ibsrv.net/gimg/www.off...452b8bf04.jpeg
https://cimg9.ibsrv.net/gimg/www.off...98a90bf74.jpeg
Here they are. Finished and ready to roll. I made two sets; one standard drop-in for OEM injectors, and one set with modified mounting brackets that were tacked on location, using a set of spacers to account for injector height, on the injectors on the manifold, custom fit for a set or 80lb injectors the guy that’s building my engine made me a can’t-pass deal on. I’m thinking of making a set of modular brackets that will clamp in place for custom fitting to non-OEM injectors, that can then be tacked in place by the end user once location is established.
The heat tarnish will be gone before any go out, even if I have to scrub it off with Scotch-Brite. An anodizing shop I use frequently tells me that a muriatic acid bath and passivation should leave them sparkly clean.
Who wants to guinea pig the OEM injector set? I can’t wait to test them out myself, but over currently got a pile of parts, waiting for a block to return for the machine shop.
Thanks. Brad.
SB 10-26-2024 06:04 PM
Originally Posted by Brad Christy (Post 4911971)
Guys,
Thanks. Brad.
pic #2 above shows a possible pin hole bottom side of weld. Enlarge photo a touch and you’ll see it. Hope it’s way pic came out, but better to mention it then not.
Brad Christy 10-26-2024 06:22 PM
SB,
I’m sure it’s just a start/stop point for the weld, but they will be pressure tested at 120lbs under water. Already the plan.
I’ve made up a set of plugs that go in the injector cups, held in place with the same clips that are used in application and utilize the same O-rings the injectors have (they can be seen on the left in the first pic in post #8), and I will acquire a couple of AN ORB caps, one of which will be modified and fit with a ball valve and a quick disconnect. I will pressurize them, close the ball valve, disconnect, dunk them in a tank and watch for bubbles.
Thanks. Brad.
Tartilla 10-26-2024 07:56 PM
Looking nice Brad. Glad you got these going. Hope people make use of them.
AmcDaniel 03-27-2025 11:25 AM
496 Fuel Rails
Hello,
Good afternoon. Are you still making the fuel rails for the 496?
Thanks!
Anthony
Brad Christy 03-27-2025 12:12 PM
Originally Posted by AmcDaniel (Post 4923061)
Hello,
Thanks!
Anthony
Anthony,
Yes sir. Or, more to the point, I can. I’ll send a PM.
You need to get your post count over 10 so you can send/receive PMs.
Thanks. Brad.
AmcDaniel 03-28-2025 08:33 AM
Thanks for the reply. Don't really have anything additional to post about as there is a lot of info already commented on by other members.
Could you just shoot me an email? My email is [email protected]
Thanks again!
MDFCUSTOMS 06-04-2025 09:47 AM
Im in need of fuel rail,, do you still make them?
Brad Christy 06-04-2025 09:53 AM
MDFCustoms,
Same answer as above. We can still make them. Send me a text: nine3seven-5four5-eight9nine1.
Thanks. Brad.
Brad Christy 06-04-2025 09:54 AM
Admin,
Can you move this to the SwapShop?
Thanks. Brad.
MDFCUSTOMS 06-04-2025 09:59 AM
thanks, sent text
1BIGJIM 06-05-2025 09:56 AM
Beautiful work Brad. :D
ashipshow 06-05-2025 03:36 PM
Brad, whats the reason for AN fittings on both ends of the rails? Just to keep possibilities open? Or are you actually using them all?
Brad Christy 06-05-2025 03:58 PM
AShipShow,
Put simply, I designed it around my intended configuration. Personally, I am using them all. Fuel enters the rail at the forward end of the port rail, then through a connector hose across the back to the starboard rail, then out the vertical fitting at the #2 position, headed for the regulator.
https://cimg4.ibsrv.net/gimg/www.off...2c5abb5a5.jpeg
https://cimg5.ibsrv.net/gimg/www.off...4459c79f0.jpeg
https://cimg7.ibsrv.net/gimg/www.off...bf0032a3a.jpeg
For the second one I built, and have since sold, I made it the same way. I believe the user is going to block of the forward fittings on both rails with AN caps, plumbing it for dead-head, like the OEM rail. As I understand it, they are retaining the rest of the fuel delivery system. It's going on an HP3.
I could also weld a cap on the forward end of the port rail and use a standard injector cup at the #2 position, and it would only be configurable as dead-head. It's really kind of wide open as to how it can be configured. The only thing that is critical is the relationships between the injector cup locations and the mounting tab locations. And those are unaffected by any deviations end-of-tube.
Thanks. Brad.
Brad Christy 06-10-2025 01:30 PM
Guys,
For the record….
Do we know if the Merc and VP 8.1 fuel rails are mechanically interchangeable?
Thanks. Brad.
