-   -   496HO Pops and Backfires (https://www.offshoreonly.com/forums/general-q/384029-496ho-pops-backfires.html)
Bbaker3116 10-24-2024 07:42 PM
Alright guys, I need a 496 wizard.
Dual 496HOs. They are the older style without the cool fuel box on the side. Both were running fine. Port motor started to overheat, killed it and limped back on starboard.
Changed both sea water pumps and went ahead and put all new NGK TR5 plugs(it had delcos). Got everything back together and port motor fires right up and does everything it’s supposed to. Starboard motor fires up for a few seconds on what sounds like only 3 or 4 cylinders. Might pop out the intake or backfire out exhaust and dies.
Hooked a computer up and checked codes, NONE. All the data I can see on the computer seems to be reading correctly (not sure if it’s actual live data or just commaded values).
Double checked all plug wires and they have no visible damage, put old plugs back in it. I have swapped pretty much every sensor that would make the engine run from port motor to starboard. Map sensor, cam, crank sensor, idle air control valve, ecu’s have been swapped. Fuel pressure is over 40psi and holds while cranking and doesn’t bleed down past 35psi after shut off. Port motor fires up and runs still.
I have checked I am getting 12v on the power going into 2 of the 3 plugs on the ecu. Not sure if there is another power wire to check. I have check and am getting 12v on the ignition wire at the engine plug. Main power relay is getting 12v. No blown fuses. Checked and made sure all plugs were still plugged in, didn’t pinch any wires in the 2 inner manifolds when I re installed them.
I have put an inline spark tester on one cylinder and a noid light on another, it doesn’t get consistent spark or fuel. Spark light will flash a few times here and there and noid light will light up one time and not again.
So, has anyone had a similar issue? Anything else I could check?
underpsi68 10-24-2024 07:56 PM
Does the tach do when the engine is barely running?
Bbaker3116 10-24-2024 08:07 PM
Yes tach reads rpm while cranking and running around 800rpm jumps around while barely running
Griff 10-24-2024 11:17 PM
Since it was running fine, 98% chance that something you did caused it. Not saying you did anything wrong, though. I would closely inspect all areas of the engine that could have been touched/moved when you did the seapump and plugs.
You say you came back on the starboard engine. Do the engines feed off separate fuel tanks??
sutphen 30 10-25-2024 07:30 AM
try disconnecting the tach on that side.then look at live data and see if something is a miss.I'd say cam or crank sensor but they usually work or not.
Bbaker3116 10-25-2024 07:42 AM
I agree, and have looked everything over. Not even really much down by the sea pump to cause this. Engines run off the same fuel tank.
Bbaker3116 10-25-2024 07:45 AM
I’ll try that, it’s acting like a cam/crank sensor problem but I have swapped both. And I feel like if the wire got messed up somehow and it’s not getting signal from these sensors, it would throw a code.
Brad Christy 10-25-2024 09:08 AM
BBaker,
I'm no wizard, but I have had my fair share of experience with the 496HO.
A Good Read
Do you have a Rinda TechMate scan tool? You can use it to do a cylinder delete sequence for both injectors and ignition to help determine if you are actually missing cylinders and which ones. It sounds like just about everything else in is order, so I'd start there.
Thanks. Brad.
87MirageIntruder 10-25-2024 09:14 AM
Have you swapped the plug wires from the good running engine over to the bad running engine? Plug wires are something you obviously touched, maybe causing one or 2 to fail internally. These 496s are at the age where the plug wires are failing.
Bbaker3116 10-25-2024 05:55 PM
engine should still run on 2 dead cylinders, hell even 3
