Crank Trigger Solutions
As with anything......this has been a project. Through the evolution of my PSI engine builds I've discovered that any of the current market solutions for a crankshaft ignition trigger while seemingly, in fact are not for marine applications. Sure MSD/Holley have a flying magnet solution, but the trigger holder uses the accessory holes on the block that are being utilized by the sea pump and alternator. There is a OEM solution, but that only works on a gen V and VI engine as it requires the use of a late model timing cover. So, I defined the parameters of what I needed:
Trigger sensor bracket that bolts to the timing cover like a timing pointer. Utilizes a OEM produced hall efect sensor for economical and availability reasons. Adjustable to set air gap and accommodate for snout flex/wobble. A ferrous trigger wheel. No magnet inserts to reduce parts and increase reliability. 60-2 configuration to offer the highest revolution for individual cylinder tuning and dual use with a TFX or Plex PLA 2000+ combustion analyzer. This is what I have come up with: https://cimg7.ibsrv.net/gimg/www.off...28217340be.jpg https://cimg8.ibsrv.net/gimg/www.off...8140234903.jpg https://cimg9.ibsrv.net/gimg/www.off...56b3c41722.jpg |
What is the OEM solution for the Gen-6. I am putting MSD Crank triggers on mine and need some way to mount the sensor.
I have already purchased my MSD crank triggers for both engines. Do you offer a sensor bracket for the gen-6 engine? |
Originally Posted by tfarmer
(Post 4916811)
I have already purchased my MSD crank triggers for both engines. Do you offer a sensor bracket for the gen-6 engine? I do have a bracket for the Gen V and VI just like the 525 sensor holder. The issue I think you might have is that it will be fixed and non adjustable. It would be useful with a Daytona Sensors Ignition box however. I can put a kit together for you if you think this is a viable solution for your needs. https://cimg7.ibsrv.net/gimg/www.off...bd141bb9ba.jpg |
Originally Posted by Precision
(Post 4914829)
Holley no longer offers their 60-2, and beyond that, it did not have a register for the id of the balancer nor a register for the accessory pulley. It was actually a pretty crude piece. I have one on the shelf and it was going to be more work than it was worth to weld it up and machine it to make what i needed and still need a second wheel for the other engine.
The water crossover has no viable location to mount a trigger without massive alterations. Even then, you have attached the sensor bracket to the crossover that is also holding the supercharger belt brackets. Trust me when I say, I exhausted all other options. LOL |
(Post 4918197)
| All times are GMT -5. The time now is 08:27 PM. |
