Fitting material
Nickel Plated Aluminum AN fittings vs Anodized for fresh water lines. What have you had the best luck with?
Originally Posted by jeffswav
(Post 4915293)
When using -16 AN fittings for fresh water use, what material holds up the best? I have tried Black and Blue/Red aluminum fittings. Both only last about 4 years before corrosion on the inside begins. Anyone try nickel plated aluminum?
Originally Posted by Bondo
(Post 4915300)
Ayuh,..... Stainless steel,....
If you know someone with a TIG welder I'm sure you could make one if you can't find one.
Teague has a lot of high-end stainless etc. worth a call... VERY nice fittings I may add.
(Post 4915344)
Feel free to post a link for a stainless steel -16 hose end in a 45 degree.
(Post 4915370)
Originally Posted by Diamond Dave
(Post 4915349)
nothing wrong with push lock
agree, what are you using these for? push lock is good for 300psi on average and I dont know of anything getting near that on a boat other than the trim systems.
| All times are GMT -5. The time now is 06:34 AM. |
