-   -   K Plane painting or powder coat (https://www.offshoreonly.com/forums/general-q/384418-k-plane-painting-powder-coat.html)
Anth0ny1954 12-17-2024 03:49 PM
Has anyone had any experience powder coating their K Planes?
Griff 12-17-2024 04:03 PM
K Planes are powdercoated from the factory. The hardest thing is stripping the old powdercoat.
I have a set of 280 K Plane plates for sale in the Swap Shop and they would prob cost less than having yours stripped and repowdercoated.
280 K Plane plates - Offshoreonly.com
Anth0ny1954 12-17-2024 04:08 PM
K plane
Where are you located? I have a couple of delivery options
Griff 12-17-2024 07:43 PM
Primary house is in Omaha area and have a condo at Lake of the Ozarks.
Griff 12-21-2024 12:36 AM
BTW, you can't send or receive PM's until you have at least 10 posts on OSO. If you need to, just make 3 more post in this thread with 8, 9, 10 in them
Anth0ny1954 12-21-2024 07:20 AM
Posts
Thanks, I just realized that. Great advice
Anth0ny1954 12-21-2024 07:21 AM
9
Posting to add
Pnb 01-14-2025 01:26 PM
Is there anything special about the powder coat used on these?
I may want to have mine powder coated again as they are showing a few spots of minor corrosion.
Griff 01-14-2025 05:03 PM
I doubt there is anything special, but the key is the prep. It will still cost more to strip and powdercoat than to buy a set of clean used plates.
Wally 01-15-2025 06:15 PM
i stripped and powdered a set of k-planes for my old stinger....took me a LOOONG time in the sand blaster booth at work. There are a few strippers that do put dents in it though....i have heard that the primer for PVC piping seems to attack it good. Never tried it though. I used an aircraft paint stripper and did a couple rounds of that placed in a garbage bag so it doesn't dry out...then i took it to the blaster for the stubborn parts.
As far as powder goes..talk with the powder coating guys...they usually know what they are doing. The guy i took it to, put what i felt, a thicker coating on them after i told him they would be in the water all the time when boats in the water. He also baked them to off-gas any chemicals before coating that may be left behind so the powder doesn't bubble during curing..
