CoolFuel Module
Guys,
https://cimg6.ibsrv.net/gimg/www.off...181d7372b.jpeg https://cimg8.ibsrv.net/gimg/www.off...79c7b0529.jpeg https://cimg9.ibsrv.net/gimg/www.off...235003f58.jpeg So which CoolFuel module do I have here? Came off my 2001MY 496HO. Looking to put it in the SwapShop, but I figure I need to know which one it is. Thanks. Brad. |
Looks like cool fuel 2. I have the cool fuel 3 with dreaded paint issues
That's a cool fuel 2. The 2 uses the spin on fuel filters that look like an oil filter.
Yep, count your blessings...
Its still a dumb solution from Mercruiser though... They wanted to design a drop in solution for OEMs and didn't want to have to integrate with external components.. I understand the desire, but coming up with poor designs to avoid it sucks.. If they implemented a fuel return line instead of a closed system, they could have completely avoided the cooler requirements.. A lot of people move away from the cool fuel setup and add a return line to the tank. Its not a necessary change, but I think if I was going for a performance build, I'd consider it as you can implement an adjustable FPR as part of the change. |
Originally Posted by ashipshow
(Post 4919476)
Its still a dumb solution from Mercruiser though... They wanted to design a drop in solution for OEMs and didn't want to have to integrate with external components.. I understand the desire, but coming up with poor designs to avoid it sucks.. If they implemented a fuel return line instead of a closed system, they could have completely avoided the cooler requirements.. A lot of people move away from the cool fuel setup and add a return line to the tank. Its not a necessary change, but I think if I was going for a performance build, I'd consider it as you can implement an adjustable FPR as part of the change. Oh, we've completely ditched the entire fuel delivery system, from tank to intake manifold, with the entire component entourage mounted on the transom; pump, filter and regulator (the cooler is where the CoolFuel module used to be). We are not running a return to tank, as there was no convenient way to do so. But running a return line back to the filter head works as long as it's not susceptible to heat soak from the engine. With the return line only returning cooled fuel back to the filter head, once the air is purged/consumed, we should be good. I was primarily asking here so I knew how to list the CF module for sale. Thanks. Brad. |
(Post 4919500)
Are you looking for a price on what yours is worth? I don't think the module as a whole is worth very much as people generally just replace the pump or the regulator when they go bad.
Originally Posted by Ryanw10
(Post 4919569)
Primarily, I was asking if the unit in the eBay link was the same as what I have. Thanks. Brad. |
(Post 4919569)
Originally Posted by Griff
(Post 4919582)
Merc does not sell just the pump any longer, so you have to buy the entire unit for about $900, but after market pumps and regulators are available for about $200.
Edit: looks like this a gen 3 pump. Shouldn't the only difference be the electrical connector? |
(Post 4919592)
https://www.mercruiserparts.com/866169t01-pump-kit-fuel
First off - thanks for posting this photo as I have to replace my high pressure pump and can barely see the thing...can reach but limited visability.
Second, I ordered a pump on amazon which the Merc Manual says is compatible.- hoping it is the right one. Third - is the connection to the cool fuel tube just an O-ring? |
Originally Posted by Swamplizard
(Post 4919635)
(Post 4919635)
(Post 4919695)
Yes, the small end just presses in place
Which connection are you referring to? The fuel output? Thanks. Brad. |
yup. Pump is threaded on one end and not threaded on the other. Pushes into the cool fuel housing and I think it has an O-ring....but wont know until I take mine apart.
(Post 4919717)
Can you post a pic of the new pump you have? Maybe that will shed some light….? Thanks. Brad. |
(Post 4919699)
Griff, Swamp,
| All times are GMT -5. The time now is 12:21 PM. |
