-   -   spark plug 7.4 454 9.5:1 crate engine gen V carb (https://www.offshoreonly.com/forums/general-q/385074-spark-plug-7-4-454-9-5-1-crate-engine-gen-v-carb.html)
Lief 04-03-2025 09:03 AM
Hello,
I need help with selecting the spark plug.
The marine long block, carbureted vortec head 10141279, 100cc, on a 7.4L which spark plug for ignition thunderbolt IV, about 9.5:1 compression.
The cam is 0.51 lift on both I/E.
Going in an old 1988 pachanga 22 thats about 3500 lbs. + gear + and bravo 1 outdrive
thanks in advance, all input is very appreciated, including
a) initial timing,
b) spark plug gap,
c) spark plug,
d) ...
thanks!!! I did search and search,
regards
Lief
new build 7.4 vortec
AllDodge 04-04-2025 07:06 AM
Go with original spec MR43T, .035 and 8*
Lief 04-04-2025 08:18 AM
Thanks!!
GLENAMY 242SS 04-04-2025 12:15 PM
As for timing it depends which module you have.
Set to 32-34* at full in timing
SB 04-04-2025 12:17 PM
Whooa, hold off if doing today.
i could swear the l29 heads you say you have, take longer reach plugs than the r43t’s.
I don’t have the time to look this afternoon but i saw this and needed to say something before you proceed.
Lief 04-04-2025 06:31 PM
The heads are the larger oval ports.
I have the 24 ignition module. So max offset is idle initial timing + 24 degrees max.
Waiting...
Thanks for your input
Lief
Spark plug combustion chamber
SB 04-04-2025 08:06 PM
10141279 Are the L29 Vortec heads.
They take a longer reach plug
like the NGK TR5 or the AcDelco mr43lts.
Always double check free advice, which mine was too :)
Griff 04-04-2025 10:04 PM
I'd start with 8* base timing which should keep total to around 32*. Total advance with a V8-24 is around 3750rpms. Verify the total advance as there can be some variance with modules
Lief 04-07-2025 10:40 AM
Measure depth of threads ~0.7xx
The reach on the AcDelco mr43lts seems correct to the depth I measured. Thanks!!
