Vinyl / Boat Flooring
Who is the supplier/ where can I buy the Vinyl type flooring material used in the Cockpit areaof boats.
Any info much appreaciated Thanks John |
Johno
Go to the top of the page and run your mouse across
"Forums/Boards" untill a drop down menu apears. Now drag your mouse down to "Search" and click on it. In the gray field under "Search by Keyword" type in "Pirelli Flooring" hit the gray button at the bottom that says perform search now. This should give you about 19 topics that were posted on the subject. Everything from links to contacts to install tips. I have mine set to search all open forums. Cordell |
I found mine at Cabela's. The textured kind. I think they have it in tan and gray.
John,
Cigarette uses lonseal, lonwave is the pattern, they want $64.00 a yard at a place in Florida, I priced it through my flooring contractor for $32.00 a yard. Be sure to use the right glue on what ever type of flooring you use. |
PM Indy...He just redid his entire floor with Perreli.
John, I'll check some of my suppliers tomorrow and see if I can get it at contractor price.
You can get "Lonseal" from most any flooring store...I think I was quoted about 25-30 a yard.
Cuda If you have a source, I'll swap ya a piece for those diverters if you still need them. I never heard back from ya. I need a piece about 8X8 The white stuff with the raised non skid circles. Dan |
Sorry I haven't gotten back Dan, I've been so damn busy with work that I haven't had time to do anything. I can't complain though, you gotta make hay while the sun is shining!:) I haven't even fired up one of the boats in over two months.:mad:
| All times are GMT -5. The time now is 12:34 AM. |
