Quickfuel Marine 850 Carb
Hello,
I know there are many variables regarding the carb setup, I have a 540 with flat top pistons 305 AFR heads nice setup but need a little help with the carb. I have seen some posts claiming they did nothing to the carb others say its just to lean at wide open throttle. Should I leave the setup or change it prior to running it. Any suggestions are welcomed. |
AFR Gauges
I run some Quick fuel 850's with a blow through carb set up and I really did not how rich they were running until I put the AFR gauges on it
Install afr gauges, takes out all the guess work, might make difference between making ashtrays or wasting fual.
Don't make the mistake I made. I rebuilt one of my motors and dynod it with the original carbs that came on it and then I dynod it with a holley xp 950 I had bought earlier in the year (brand new). The motor picked up 20 hp so I ordered a 2nd holley xp 950. I put the 950 I dynod on the motor in the boat and put the new 950 on the motor I just rebuilt. It ran fine and seemed normal until I did a full throttle run and the end of the season and I burnt a piston. When I rebuilt the motor (the 2nd time) and we dynod it that new carb was extremely low on fuel. We had to do a lot of work to get the AFR right on the dyno. I guess my point is that 2 of the same carbs can be completely different so either dyno it or get some AFR guages.
Quote:
Mine were definitely on the rich side , I went through a lot of spark plugs before I got the AFR numbers under load where I wanted them .
Quote:
Once you install O2 sensors to tune you'll never go back to guessing, best thing I've ever done as far as tuning in water.
| All times are GMT -5. The time now is 04:23 PM. |
