Livorsi
Old 06-11-2025 | 08:29 PM
Default Livorsi
We have a brand new Livorsi fuel pressure sending unit and a brand new Livorsi fuel pressure gauge. The gauge is not displaying fuel pressure. How do you test the fuel pressure sending unit? Is it based on ohms or voltage?
Jerry LeBlanc is offline
Old 06-11-2025 | 11:58 PM
Could be the sender is not getting a good ground
Griff is offline
Old 06-12-2025 | 03:55 AM
SB
Directions and trouble shooting chart:
https://livorsi.com/pdf/GIFP,GIFP60,...IWP,GIWP15.pdf
SB is offline
Old 06-12-2025 | 03:57 AM
SB
Direction pages for all livorsi products
https://www.livorsi.com/tools.htm
SB is offline
Old 06-12-2025 | 04:44 AM
I recently tried to install a livorsi rudder indicator, and they sent me the wrong sender for the Rudder.
Ryanw10 is offline
Old 06-12-2025 | 07:55 AM
Jerry,
Most gauges use a reference voltage, usually 12v, and the sender is simply a resistor, regulating voltage. If you're getting nothing, check 12v at the gage and sender, and continuity from the gage to the sender and from sender to ground. One of those will be the problem. Or the gauge is bad.
Thanks. Brad.
Brad Christy is offline
Old 06-13-2025 | 09:33 PM
Thank you guys for the help
