Originally Posted by madmax2
(Post 4930837)
What do I know, I'll keep looking for information
Anyway, looks like you can get ASM’s intake still. https://azspeed.com/product/bb-chevy...tion-manifold/ |
1 Attachment(s)
Originally Posted by Tartilla
(Post 4930931)
(Post 4930835)
Modifying a dual plane is more difficult, the channels are in different planes and the injector will be in different planes as well.
I want the Holley Hi-ram, nice product.... I have it scheduled, maybe they will release an oval port version The GM RamJet 502 it's nice, the port has fewer curves than the Mercury/ASM, no hay data about torque/power rpm band on 454. No power added at the moment. I'm looking forward to some aluminum heads (AFR, TFS, ProMaxx) but I was thinking about that later and making one improvement at a time. Lingenfelter/Accel make a BBC two version of the Super Ram at the time...SuperRam Stealth, I'm going to investigate these too |
Originally Posted by SB
(Post 4930944)
OEM automobile man’s have to deal with hood height.
Anyway, looks like you can get ASM’s intake still. https://azspeed.com/product/bb-chevy...tion-manifold/ They've been selling an oval port on eBay for a while now.
Originally Posted by articfriends
(Post 4930949)
Ive extensively dyno tested the proflow intake, it makes outstanding hp. It is NOT a tq monster however with runner length at only about 5.5" or so, its very hard to get a boat thermostat under the throttle body but can be done with enough work and the right one. The throttle body itself by design needs a air flow entry device or it kills hp, on any single engine boat its virtually impossible to put that on tb and a cone filter that doesnt restrict flow/ kill hp . Putting a 90 degree elbow to feed a proflow intake or ANY intake NA is a waste of time, at that point youd be better having a conventional intake/TB.. As far as a oval port version, they made one once upon a time, Ive used 2 of them in builds, they will never make one again, its out of the question for unknown reasons, Smitty
(Post 4930951)
The holley high ram 300-963 is a great looking intake, I been waiting to test one. In YOUR application it would be a HORRIBLE choice with CSA of 5.31" especially with thought that your going to be IRON vortec heads and the fact your engines small as BBC go at 454 ci. I cant stress this enough. You want to make supreme tq down low over what you had before/ have currently, that holley would make NO tq in that idle to 3000 your looking for as its sized for 500 + cubic inches and rpm band to 8000+. IF I had to pick a efi intake for a small cube bbc with idea of most tq from off idle to 3000, I would pick the ram jet 502 intake, its on small side but packaged nice.
I didn't find any comments about the RamJEt 502 and a 454, on the other hand it is the only oval port.;) |
(Post 4930949)
Originally Posted by Rookie
(Post 4931053)
Smitty, It appears that Spectre has stop making their Spectre 9604.
(Post 4931020)
They advertise that it runs better than the GM Ramjet 502... but it is a rectangular port.
They've been selling an oval port on eBay for a while now. Oval port discontinued due to performance issues (I read it on an Edelbrock forum) Holley say that power range of Hi-ram it's 1500-7000 :confused: I didn't find any comments about the RamJET 502 and a 454, on the other hand it is the only oval port.;) |
I understand the point, my heads are not peanuts, they are oval 049, port matching with a gasket,
I was thinking of a long port design like the tunnel ram but with less height, the MR 500/525 intake seems to have longer ports than any other I've seen, it has a CSA that appears to be good (I don't know its measurements) and a large plenum. From my limited knowledge, I don't see the downside to using it in a 454 NA; teachme please. Another point that I find beneficial is how the injectors are located. https://cimg9.ibsrv.net/gimg/www.off...93791ba21c.jpg https://cimg6.ibsrv.net/gimg/www.off...70c9f95296.jpg |
(Post 4931141)
(Post 4931079)
Theres (4) left in world to be purchased : https://ebay.us/m/lxKTMx , IDK why they discontinued that bell mouth
You have one? :ernaehrung004: Thanks. Brad. |
| All times are GMT -5. The time now is 02:48 PM. |
