carter AFB/weber 9780S rebuild help
I've torn down, cleaned and almost have a Weber 9780S carb back together...but have 2 parts from the kit that i cant figure out...
one is a rubber seal maybe 1/4" in diameter, thought maybe accelerator pump shaft? but it s too tight on the shaft...the other is a thin ,metal washer, maybe under accellerator pump spring? any help would be much appreciated.. https://cimg4.ibsrv.net/gimg/www.off...730af55209.jpg |
the small one goes under the choke housing..
| All times are GMT -5. The time now is 10:35 PM. |
